Translations:Tuning Guide/17/en
When above steps are done, you can tune the Stopping Behavior. For this purpose use the Advanced/Rudder Stop parameters. Value determine how aggressive the Rudder Stopping and Steering is. If you like sharp stops, you should set value between 6 to 8. If you like extra sharp behavior, then value higher than 10 are good for you. High value will add extra stress for servos and mechanics, so you should be carefull. If you like smooth stopping so that steering is also very smooth, you should set values between 5-7. If value is too low, the rudder reaction could feel delayed. In case the tail stopping is not equal or overshooting to one side, you can decrease the Rudder Stop - A or Stop - B. Stop - A will affect stopping from Clock-Wise turn, while Stop - B will affect stopping from Counter Clock-Wise turn. Stop - A is usually smaller by 1 - 2 points from Stop - B.
