Translations:Tuning Guide/22/en
Revision as of 09:06, 2 August 2026 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
Set the Sensor/Rotation Rate parameter to achieve required Flip and Roll Rate. Be carefull to not set it higher than your mechanics can handle. From certain point the model will stop increasing the rate. This mean your Cyclic Ring or Head Speed could be too low. Maximum Flip/Roll Rate for the most models is roughly 360°/s. If the value is too high, steering will initially react very quickly, but then it will slow down.
