Translations:Tuning Guide/17/en
Revision as of 10:29, 2 August 2026 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
(OPTIONAL) When above steps are done, you can tune how sharp tail will behave. For this purpose use the Advanced/Rudder Feed Forward parameter. Value determine how aggressive the Rudder steering is. If you like quick reaction, you should set value between 6 to 8. If you like extra sharp behavior, then value higher than 10 are good for you. High value will add extra stress for servos and mechanics, so you should be carefull.
