Translations:Tuning Guide/28/en
Revision as of 10:29, 2 August 2026 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
If you reached the point when increasing Elevator Filter is not possible, use parameter Swashplate - Stop Smoothing. Stop Smoothing benefit is visible even in situation when Elevator Filter is low. At the same time you can also use Swashplate I-relax that is available in the 3DMaster mode. This is helpful for extremely hard 3D flying, but for normal pilots it is not recommended or needed.
