Translations:SpiritW1 Binding/3/en
Revision as of 10:30, 2 August 2026 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
- Insert Bind plug at the SYS port and connect Power supply to the Spirit W1/W3 unit. You can connect BEC or 1-3S Battery at the THR, AUX, T1 ports.
- Spirit W1 unit will start to blink with the Status LED periodically.
- Then power up your Wave radio.
- Radio will automatically bind to the receiver when using new Model profile. You can also Bind anytime manually as described in the section above.
- After successfull binding Spirit unit will stop blinking and will initialize. Then you can remove the Bind plug.
