Problèmes et Solutions
Revision as of 16:56, 10 December 2016 by Jocelynr (Talk | contribs) (Created page with "Augmentez le gain cyclique et/ou augmentez le gain gyro dans l'émetteur. Ajouter de l'expo dans l'émetteur.")
| Description du problème | Solution |
| Le plateau cyclique ou l'anti-couple se décale après l'initialisation. | Vérifiez les trim et subtrims. Les manche en position neutre doivent correspondre à 0% dans l'onglet Diagnostic. Augmentez la zone morte des manches "Stick deadband" dans l'onglet Advanced |
| L'anti-couple ou le cyclique est imprécis | Augmentez le gain cyclique et/ou augmentez le gain gyro dans l'émetteur. Ajouter de l'expo dans l'émetteur. |
| Aggressive cyclic pitch movement or fast forward flight leads to rapid, large tail oscillations | Decrease pirouette consistency in the Advanced tab gradually by 10 until this disappears. Check the tail mechanics for binding. |
| Model oscillates in elevator or aileron axes | Decrease cyclic gain in Sensor tab. |
| Tail oscillates rapidly | Decrease gyro gain in the transmitter. |
| Model pirouette rotation is too slow/fast | Increase/decrease rotation speed for rudder in Sensor tab. |
| Servos jitter randomly without external influences | Check the cable connection between the receiver and the unit. |
| During stationary pirouettes model drifts | Check the Subtrim configuration in the Servos tab. It seems to be inprecise. |
| Aggressive elevator stick movement leads to bouncing | Increase elevator filter in Advanced tab and/or decrease cyclic feed forward in Advanced tab. |
| Cyclic feel is delayed or disconnected | Increase cyclic feed forward in Advanced tab. |
| Elevator servo is not moving when initialization is finished | Flight log from the previous flight was saved. View the log in the Diagnostic tab and fix reported problem. |
| Swashplate is jumping in a cycle when initialization is finished | The unit was started with the Rescue mode engaged. Turn off the rescue from your transmitter. |
| Rudder stop is not equal for both sides | Check rudder servo center position, rudder mechanics. You can also try to lower rudder limit for the side where bounce-back occur. |
