Spektrum
Revision as of 13:17, 9 January 2017 by Spiritdm (Talk | contribs)
Setup guide
for
DX8 or compatible
1 For PWM and Satellite connection – method 1. (requirement - 6ch radio)
  • Flight Modes
  • Gyro Gains in the transmitter
  • Normal (Rate) mode
  • Rescue or Stabiilsation
  • ∗Bank Switching
∗Bank Switching in this method can be used only with Spektrum DSM2/X satellite and 7ch radio.
1.1 Flight Mode setup
Set the Flight Mode to F Mode switch and Hold flight mode to Elev D/R.
So the flight modes can be switched with F Mode switch on your transmitter, while Hold flight mode will be on the Elev D/R switch. Normally this is unwanted, but we will use Hold flight mode for the Rescue and/or Stabilisation modes. In this configuration we can use benefits of the Hold flight mode, because of higher priority.
Set Sw to Hold switch here. Throttle channel will be configured to 0% when Hold switch is on, so the motor will not spool up. In this case we will not use Hold flight mode so Throttle cut is independent of it and still will work.
Configure your Throttle Curves as you wish for all Flight Modes.
IMPORTANT: For the Hold flight mode we will configure Throttle Curve too! Because we will use this one for the Rescue/Stabilisation we can set for example 90% flat curve or just same one as for other flight modes.
 For Normal (N) you can set for example flat 70%
1.2 Gyro Gain setup
Go to Function List → Gyro
Configure Sw to F Mode. Then set the Gyro Gain for each Flight mode. For Normal the gain is mostly the highest because head speed is the lowest.
So it can look like:
  • Normal: 70%
  • Stunt 1: 68%
  • Stunt 2: 66%
  • Hold: -66%
IMPORTANT: Remember to set NEGATIVE Gyro Gain for the Hold flight mode else a special mode will not be activeted! Special mode as the rescue or stabilisation are always activated only when Gyro Gain is negative.
Gyro Gains are only for a better imagination, each model must be configured individually.
1.3 Bank Switching setup
Set Gov to Aux2 switch.
Bank Switching will be performed via Aux 2 switch.
Bank Switching in this method will work only when using Satellite. When using PWM connection type you can use Setup Method 2 described in the following part of this guide.
  • Flight Modes
  • Gyro Gains in the software
  • Rescue and Stabiilsation
  • Bank Switching
2.1 Flight Mode setup
Set the Flight Mode to F Mode switch and Hold flight mode to Elev D/R. So the flight modes can be switched with F Mode switch on your transmitter, while Hold flight mode will be on the Elev D/R switch. Normally this is unwanted, but we will use Hold flight mode for the Rescue and/or Stabilisation modes. In this configuration we can use benefits of the Hold flight mode, because of higher priority.
 For Normal (N) you can set for example flat 70%.
  • Normal: -100% (Bank 0)
  • Stunt 1: -100% (Bank 0)
  • Stunt 2: 0% (Bank 1)
  • Hold: 100% (Bank 2)
