Tuning Guide
Revision as of 12:23, 10 January 2017 by Spiritdm (Talk | contribs) (Created page with " <div id="up"></div> <center><font size="6"> Spirit Tuning Guide</font></center> <center>This guide should help you in tuning your helicopter to fit your flying style exac...")
Spirit Tuning Guide
This guide should help you in tuning your helicopter to fit your flying style exactly.
First from all, you should try default settings that are recommended. There are basic parameters that you have to set first (for example in the wizard) but other are usefull so you can adjust stick feeling, flight behavior. Basically, you can set the behavior so that it is very similar to any known flybarless or flybared system.
If you are in the state that the helicopter is flying, but you need to do some corrections, you should start with the rudder settings first.
