Jeti Integration
Revision as of 15:02, 10 January 2017 by Admin (Talk | contribs) (Usage)
From version 1.1.0 you can use the JETI integration! This mean you can fully configure Spirit units with JETI transmitters in real-time without need of a computer.
1 Requirements
  • Jeti Duplex transmitter: DS/DS 14 or 16 or 24
  • Jeti Duplex receiver with a free EX port.
  • Jeti Integration cable available in our stores.
  • Configuration file for the transmitter.
2 Wiring
The Jeti cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
On the receiver side the servo cable must be connected to the EX Bus port. For new REX receivers the port label is EX1 or EX2 (EXT port will not work). For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
  • To buy a REX receiver which allows the - you can use a telemetry sensors and the Jeti integration together.
3 Transmitter preparation
Now download the Configuration file, which has BIN extension. The file name is "Spirit.bin". This file should be copied to the "Devices" directory on the SD-Card of your transmitter. Without it you will see the error message when the Spirit device is opened.
You can copy it by connecting the micro USB cable to the transmitter similarly as to an USB flash drive. When cable is attached to the transmitter you have to confirm the USB connection. Then simply drag and drop it to the Devices directory as you are used to.
It is very important to use the same version of the BIN file as your current firmware in the unit. If the versions are not matching then an incompatibility issues could occur.
5 Integration Menu
When unit is initialized you are able to enter the Jeti Integration menu. Press the MENU button on the transmitter.
In this case, enter the configuration menu of your receiver in the Device Explorer - the entry has name of your receiver. Change the Serial Link to the EX Bus. In case of REX receivers you can use both EX1 or EX2 ports. Jeti-menurx.png
6 Usage
Warning.png Test
