YGE ESC RPM output
Revision as of 19:28, 11 January 2017 by Admin (Talk | contribs) (Created page with "== Wiring == === YGE 40, YGE60 === {| class="wikitable" ! Color ! Meaning |- | brown | Ground |- | red | Not connected |- | orange | RPM-Signal |} {{Info|File:Info.png|18...")
1 Wiring
1.1 YGE 40, YGE60
| Color | Meaning |
| brown | Ground |
Here you find the RPM-Signal on the split-cable. It is important to connect the brown lead as well, to prevent extraneous radiation.
1.2 YGE 90LV, 120LV, 120LVK
| Color | Meaning |
| brown | Ground |
| red | BEC (5,7V/7,4V/8V) |
Here you find the RPM-Signal on the split-cable (Slave). It is important to connect the brown lead as well, to prevent extraneous radiation.
1.3 YGE 60HV, 90HV, 120HV, 160HV, 200HV, 320HV (all Optos without BEC)
| Color | Meaning |
| brown | Ground |
| red | RPM-Signal |
| orange | programming-Signal for ProgCard |
Here you find the RPM-output on the short ProgCard-cable. It is important to connect the brown lead as well, to prevent extraneous radiation.
Connect Orange wire to Ground for flying, to prevent extraneous radiation
2 External Governor mode
For using external Governor with the YGE controllers, it's important to set the ESC to external governor mode!
- For our newest models, it's very easy. Just do the mode-setup and select Mode 1 (external Governor/Vbar Gov). Everything will be set to optimal parameters for use with FBL-governors and no ProgCard is needed.
- For older ESC's that don't have the mode-setup, a ProgCard is needed.
- Except for startup speed, program everything as usual.
- go to the second page of the ProgCard
- Set Startup speed to Heli middle and confirm with Enter.
- Select Gov off. and confirm 3x with Enter.
- Set Startup speed to plane middle and confirm with Enter. For confirmation you will hear another acknowledge sound as usual.
- Your ESC is now set to external Governor Mode!
- After programming, disconnect the main battery, ProgCard and patch cables.
