OpenTX 2.2
Revision as of 09:28, 12 January 2017 by Admin (Talk | contribs) (→‎Nightly Builds)
OpenTX 2.2 is at the moment not oficially released yet - it is still in a development. Because the current version is the Release Candidate it should be usable.
To allow the OpenTX Integration it is required to install the version 2.2. Previous version does not support bi-directional S.Port communication that is used for the integration.
Warning.png Pre-release versions are recommended only for experienced users. It could cause unexpected behavior!
Before doing any changes, please Backup all your transmitter profiles and the SD Card content.
18px We recommend to check the OpenTX 2.2 page prior the upgrade.
1 SD Card
First you can download the new SD Card content for your transmitter. Extract the archive and move the content to your SD Card.
2 Companion
Please download the latest Companion 2.2 software to your PC:
3 Nightly Builds
Install the Companion software as you are used to do now. Start the software and open the Settings/Settings menu.
Tick Use OpenTX firmware nightly nuilds option.
Then confirm the settings and restart the software.
After the restart you will see the Popup window with notification about the new firmware. Click Yes to download and save the firmware to your computer.
4 Flashing
  • By Companion software
  • By built-in bootloader
4.1 With Companion software
4.2 With Built-in bootloader
4.3 Troubleshooting
  • In case that you will see a Blank screen after the upgrade, please try a different Flashing method.
  • If you will see the OpenTX logo but there it will freeze, something is wrong with your SD Card content.
