OpenTX Integration
| ◦ | Settings directly in the transmitter |
| ◦ | Configuration of the unit |
| ◦ | No need for computer |
| ◦ | Everything quickly accessible |
| ◦ | OpenTX 2.2 with Lua support |
| ◦ | Receiver with S.Port |
| ◦ | Integration cable for S.Port |
1 Wiring
To enable the Integration, you have to only connect your receiver and unit according to the following scheme. Please note, that to make this possible, you will need special cable that is available in our eshop.
Shorter lead of the cable receiver - S.Port Longer lead of the cable unit - SYS port
The integration cable is used for bi-directional data transmission between unit and receiver, respectively transmitter. This include telemetry data and possibility to configure all parameters of the unit, directly from your transmitter.
It is completely separated from basic receiver part that is transmitting the channel data. Thus your existing connection with receiver can be untouched. It can work with PWM, PPM and SBus connection types.
For receiver that has a Molex connector for the S.Port (e.g. X4R, X4RSB, XSR), please use provided connector and pins so that you can easily connect it to the servo connector.
S.Port connection alone will not work – it is used only for configuration. Channel data must be transmitted by a conventional protocols such as PWM, PPM or SBus.
2 Installation
| For Heli | |
| FrSky Taranis X9D/X9D+/X9E: | http://www.spirit-system.com/dl/opentx/Spirit-2.2.0-Taranis.zip |
| FrSky Horus: | http://www.spirit-system.com/dl/opentx/Spirit-2.2.0-Horus.zip |
| For Spirit Aero | |
| FrSky Taranis X9D/X9D+/X9E: | http://www.spirit-system.com/dl/opentx/Spirit-Aero-1.0.0-Taranis.zip |
| FrSky Horus: | http://www.spirit-system.com/dl/opentx/Spirit-Aero-1.0.0-Horus.zip |
Then unzip the file and copy the „Spirit-2.2.0“ directory to SD Card of your transmitter.
3 How to open the Menu
- Press the MENU button for 1 second.
- Click the PAGE button.
- By clicking + and – buttons move to the „Spirit-2.2.0“ directory.
- Click the ENT button.
- Start the basic.lua or special.lua script by clicking the ENT button.
- Press the < button for 1 second.
- Click the PAGE UP button to reach the SD CARD page.
- By rotary manipulator move to the „Spirit-2.2.0“ directory.
- Click the manipulator button to enter.
- Execute the basic.lua or special.lua.
4 Integration Preview
5 Troubleshooting
- MLVSS sensor is known to cause interferences on the S.Port line, thus affecting all other sensors including the Integration. We do not recommend to use this sensor at least until the fix will be available.
- If you will see the Lua script error describing missing SPort function, then the OpenTX firmware in your transmitter is 2.1 or earlier.
6 Usage
