HobbyWing Telemetry
Revision as of 21:52, 10 June 2017 by Admin (Talk | contribs) (Marked this version for translation)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 60A V4 x x
Platinum 80A V4
Platinum 120A V4
Platinum HV 130A V4
Platinum HV 130A OPTO V4
Platinum HV 160A V4
Platinum HV 200A OPTO V4
