HobbyWing Telemetry
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
[hide]1 Telemetry Cable
We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit. The Red wire must be internally disconnected always!
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Model |
Battery Voltage |
Battery Current |
Consumed Capacity |
ESC Temperature |
RPM |
Platinum 25A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 40A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 60A V4 | ✔ | x | x | ✔ | ✔ |
Platinum 80A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum 120A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 130A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 130A OPTO V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 160A V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
Platinum HV 200A OPTO V4 | ✔ | ✔ | ✔ | ✔ | ✔ |
