YGE telemetrie
Revision as of 17:42, 4 August 2018 by Admin (Talk | contribs) (Created page with "Telemtrické data je možné přenášet skrze propojku '''JST-Servo'''. Je dostupná na našem [http://store.spirit-system.com/cs/prislusenstvi/33-jstservo-cable.html Eshopu].")
Regulátory YGE LVT a YGE HVT zasílají telemetrii pomocí programovacího portu. Tímto je zprostředkován přenos dat až do jednotky. Pro fungování ESC telemetrie je nezbytné mít aktuální verzi firmware v regulátoru otáček. Starší verze firmware tuto podporu nemají.
1 Telemetrická propojka
Telemtrické data je možné přenášet skrze propojku JST-Servo. Je dostupná na našem Eshopu.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
YGE 35LVT
YGE 65LVT
YGE 95LVT
YGE 135LVT
YGE 90HVT Opto
YGE 120HVT Opto
YGE 165HVT Opto
YGE 205HVT
