Установка.
Revision as of 11:57, 12 October 2018 by Gstatopen (Talk | contribs) (Created page with "Найдите подходящее место с минимальными вибрациями (как правило, оно указано изготовителем мо...")
Правильная установка Spirit играет важную роль для правильной работы модели.
Найдите подходящее место с минимальными вибрациями (как правило, оно указано изготовителем модели) для установки гироскопа.
It is VERY important that the unit will be mounted so that the unit is exactly perpendicular to each rotational axis. Depending on your preference and available space it can be mounted in eight different positions:
  • Horizontal (0°)
  • Horizontal (180°)
  • Horizontal (0° + inverted)
  • Horizontal (180° + inverted)
  • Vertical (0° - left side)
  • Vertical (180° - left side)
  • Vertical (0° - right side)
  • Vertical (180° - right side)
Mounting examples
Example 1: Position is Horizontal (180°)
Example 2: Position is Vertical (180° - left side)
In order to better insulate against any vibrations from the model, it is necessary to choose the right double-sided mounting tape. The tape should limit any transmission of vibrations from the model to the Spirit which may produce undesirable flight characteristics. Vibrations may also be caused by incorrectly balanced blades, damaged bearings, bent shafts and other mechanical issues.
