Configuration
Revision as of 13:35, 16 September 2016 by FuzzyBot (Talk | contribs) (Updating to match new version of source page)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
4 CONFIGURATION SOFTWARE
PROBLEMS WITH WINDOWS
5 SOFTWARE USAGE
5.1 CONNECTION TAB
UPOZORNĚNÍ
Swashplate
PWM – standard receiver.
PPM – single line connection.
Letový projev
Channels
  • N – Normal (Rate)
  • HL – Head Lock
FREKVENČNÍ ANALYZÁTOR
Pro snadné diagnostikování stavu je zde panel "Vibrace", určující celkovou míru vibrací na právě zvolené ose.
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
Wiring|←
Wiring]]
Up↑
First flight| First flight →]]
