Телеметрия TelMe
Регуляторы Kontronik используют специальный 5 штырьковый разъем для передачи данных телеметрии. Что использовать телеметрию регулятора, необходимо обновить его прошивку до версии 1.13 или выше. Старые версии не поддерживают протокол TelMe.
1 Телеметрийный кабель
Для использования телеметрии необходим кабель Telem KONTRONIK v2 который доступен в нашем магазине.
We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit.
2 Подключение
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the Telem KONTRONIK v2 cable should be connected to the ESC. In case of Kontronik KOSMIK you can select any free port.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik TelMe option.
4 Displaying telemetry data
5 Supported models
Model |
Battery Voltage |
Battery Current |
BEC Voltage |
Consumed Capacity |
ESC Temperature |
RPM |
KOLIBRI 140 LV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
JIVE PRO 80+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
JIVE PRO 120+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
KOSMIK 160 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 160 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
KOSMIK 200 HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 200+ HV | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
COOL KOSMIK 200 HV GOLD | ✔ | ✔ | ✔ | ✔ | ✔ | ✔ |
