TelMe telemetrie
Revision as of 15:03, 14 December 2018 by Admin (Talk | contribs) (Created page with "Zapojte kablík telemetrie do primárního portu pro Spektrum satelit. U menších jednotek Spirit se použije nativní port pro satelit Spektrum (μSpirit - SAT port).")
Kontronik ESCs are utilizing special 5-pin port connector for telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC to at least 1.13 firmware version. Older versions do not support TelMe protocol.
1 Telemetrická propojka
Telemtrické data je možné přenášet skrze speciální propojku Telem KONTRONIK v2. Je dostupná na našem Eshopu.
Warning.png We do not recommend to make this cable at home since improper connection will cause permanent damage of the unit.
2 Zapojení
Servo connector of the Telem KONTRONIK v2 cable should be connected to the ESC. In case of Kontronik KOSMIK you can select any free port.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik TelMe option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
KOLIBRI 140 LV
JIVE PRO 80+ HV
JIVE PRO 120+ HV
KOSMIK 160 HV
COOL KOSMIK 160 HV
KOSMIK 200 HV
COOL KOSMIK 200+ HV
COOL KOSMIK 200 HV GOLD
