YGE Telemetria
Revision as of 17:55, 2 September 2020 by PSzakra (Talk | contribs) (Replaced content with "Telemetriai Vezeték")
Az YGE LVT és az YGE HVT ESC-k telemetriai funkcióval rendelkezik a Programozás portban. Ez lehetővé teszi a telemetriai adatok továbbítását az egység felé. Az ESC telemetria engedélyezéséhez frissíteni kell az ESC-t, mivel a régebbi firmware verziók nem támogatták.
1 Telemetriai Vezeték
To allow the telemetry data transmission the JST-Servo adapter is required. This cable is available in our Eshop.
Warning.png It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
YGE 35LVT
YGE 65LVT
YGE 95LVT
YGE 135LVT
YGE 90HVT Opto
YGE 120HVT Opto
YGE 165HVT Opto
YGE 205HVT
