YGE Telemetria
Az YGE LVT és az YGE HVT ESC-k telemetriai funkcióval rendelkezik a Programozás portban. Ez lehetővé teszi a telemetriai adatok továbbítását az egység felé. Az ESC telemetria engedélyezéséhez frissíteni kell az ESC-t, mivel a régebbi firmware verziók nem támogatták.
1 Telemetriai Vezeték
A telemetriai adatátvitel engedélyezéséhez a JST-Szervó adapterre van szükség. Ez a kábel elérhető az [1]Eshop-ban.
It is very important to modify the cable correctly, otherwise permanent damage of the Spirit unit will occur!
1.1 Cable modification
Extremely important is the following Modification of the JST-Servo adapter cable. It is required to unplug or cut RED wire of the adapter as displayed at the photo.
2 Interfacing
Connect modified JST-Servo adapter to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
Servo connector of the JST-Servo adapter cable should be connected with the Blue Servo connector of the YGE ESC.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the YGE LVT/HVT option.
4 Displaying telemetry data
5 Supported models
Model |
Battery Voltage |
Battery Current |
Consumed Capacity |
ESC Temperature |
RPM |
YGE 35LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 65LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 95LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 135LVT | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 90HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 120HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 165HVT Opto | ✔ | ✔ | ✔ | ✔ | ✔ |
YGE 205HVT | ✔ | ✔ | ✔ | ✔ | ✔ |
