Pontatlan Mentés
Pontatlan Mentés vagy Stabilizáció :
Perform Bench testing first. If it is correct, you are ready to fly.
1 Bench testing
If rescue or stabilisation is not precise, do the following test:
- Put model at a table and engage the rescue/stabilisation.
- Swashplate should be perfectly level. If model has inclined skids, swashplate will be tilted backwards little bit to compensate this attitude.
- When model is taken from table and any of the mode is engaged, swashplate should compensate any inlinaction in attitude of the model/unit.
- Swashplate should counter-act to any movement so that model is forced back to the horizontal level.
- When model is tilted forward, swashplate should tilt backwards (with the most helicopters).
- When model is tilted left, swashplate should tilt right and vice versa.
2 Settings for the best performance
There are two parameters that can greatly improve reliability and precision of the Stabilisation and Rescue modes:
- Stabi Correction
- Extended Signal Processing
Both can be found in Advanced - Expert Settings.
Generally default settings should be suitable for the most models. With default settings both parameters are disabled. If you are in doubt, please use this settings.
If you are unable to achieve precise behavior with basic maneuvers, enable Extended Signal Processing. This mode is suitable for models that are producing high vibrations or a kind that is strongly interfering with sensors.
For advanced pilots that are performing complicated maneuvers parameter Stabi Correction can be helpful. Use this parameter only if default settings are not satisfying and model is in a good condition. Otherwise results can be worsened.
- Mi a teendő, ha a Mentés vagy Stabilizáció nem pontos?
- Nagyon fontos ellenőrizni, hogy a Pozíciók és az Imbolygó/Swashplate paraméterek megfelelően vannak-e konfigurálva. Ha nem, akkor a Mentési és Stabilizációs módok sem fognak megfelelően működni. Győződjön meg arról, hogy a Diagnosztika fülön minden irány megegyezik a bot tényleges mozgásával. :#Ellenőrizze, hogy az egység mindhárom tengelyen igazodik-e. Az igazítási hiba kb. max 1° lehet. Pontosan kell fel szerelni az egységet a helikopter vázához. Csak egy kétoldalas ragasztószalagot használjon. Az egységnek nem szabad billegnie vagy mozognia. A rögzítésnek sziklaszilárdnak kell lennie.
- Mentés és a Stabilizáció szinte bármilyen körülmények között működhet. De abban az esetben, ha a rezgések rendkívül magasak, nem garantált. A rezgéseket a spektrális elemzéssel ellenőrizheti a szoftverben, különösen az Y-csűrő tengelyen, ahol ezek többnyire a legmagasabbak.
- A Helikoptert az inicializálás közben vagy az inicializálás után megdöntötték (egy ideig oldalra vagy fejjel le/fel felé billent). Ha az inicializálás után mozog helikopterrel, győződjön meg arról, hogy az imbolygótárcsa beáll vízszintesre és kollektív, pozitív irányba mozdul, amikor a mentést bekapcsolja.
- A Helikopter ESC-je hűtő ventilátorral van felszerelve,, amely ultrahang frekvenciát gerjeszt. Ezt ismertek a HobbyWing ESC fan-ok. Ez nagy hatással van a mentési és stabilizálási módok pontosságára.
- Ha a mentés aktiválása során a modell mindig ugyanarra az oldalra dől, akkor az alapvető szervó beállítások nem helyesek. :Kérjük, ellenőrizze, hogy az imbolygó tárcsa tökéletesen kiegyenlített-e, ha a Servos/Subtrim (tuning) ra lép. Az ellenőrzés végrehajtásához elengedhetetlen a Ciklikus szintező használata.
A mentés ellenőrzésének legegyszerűbb módja a repüljön a helikopterrel nagyon egyszerű módon (az Ön stílusában). Ezután közvetlenül a repülés után, amíg a rotor már nem forog, aktiválja a mentést/stabilizálást. Ha látja, hogy az imbolygótárcsa vízszintes helyzetben van és helikopter is, akkor a repülés közben is bármikor működnie kell. Ez nagyon biztonságos módszer a művelet ellenőrzésére.
