Configuración
Revision as of 12:27, 19 September 2016 by Zexx86 (Talk | contribs) (Created page with "Niveles de vibracion:")
1 CONEXION AL PC
Es necesario instalar nada.
2 CONEXION CON LA UNIDAD
NOTA
4 CONFIGURACION SOFTWARE
NOTA
PROBLEMAS CON WINDOWS
5 USO DE SOFTWARE
NOTA
Posicion
Swashplate
PWM – receptor standar.
Channels (Canales)
Failsafe (a prueba de fallos)
NOTA
  • N – Normal (Rate)
  • Y - aileron axis (aleron)
  • Z - rudder axis (cola)
  8. Stop the motor.
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
