Configuración
Revision as of 12:56, 19 September 2016 by Zexx86 (Talk | contribs) (Created page with "Cyclic Ring Activated (Cyclic Ring Activado):")
1 CONEXION AL PC
Es necesario instalar nada.
2 CONEXION CON LA UNIDAD
NOTA
4 CONFIGURACION SOFTWARE
NOTA
PROBLEMAS CON WINDOWS
5 USO DE SOFTWARE
NOTA
Posicion
Swashplate
PWM – receptor standar.
Channels (Canales)
Failsafe (a prueba de fallos)
NOTA
  • N – Normal (Rate)
  • Y - aileron axis (aleron)
  • Z - rudder axis (cola)
Niveles de vibracion:
'Procedimiento de medicion.'
  8. Pare el motor.
Reconociendo las vibraciones
NOTA
BEC TESTER (TESTEADOR DE BEC)
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
Cyclic servos reverse
  • Head-Lock mode: 1% to 100%
WARNING
  • ESC with RPM output
  • ESC without RPM output
