HobbyWing Telemetry
Revision as of 13:48, 11 May 2022 by Admin (Talk | contribs) (Marked this version for translation)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC firmware to a recent, non VBar firmware.
1 Telemetry Cable
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
Warning.png Please update your ESC firmware to the most recent firmware, but one which has not "VBar" in the name. Otherwise all telemetry values will be Zero.
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 25A V4 x x
Platinum 40A V4 x x
Platinum 60A V4 x x
Platinum 80A V4
Platinum 120A V4
Platinum HV 130A V4
Platinum HV 130A OPTO V4
Platinum HV 160A V4
Platinum HV 200A OPTO V4
