Avian Telemetry
Revision as of 20:37, 15 May 2024 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎français • ‎italiano • ‎русский
Spektrum Avian ESCs are able to provide full telemetry through a single connection of the ESC throttle cable. The same cable is used to transfer throttle signal back to the ESC. The transmission is bi-directional.
1 Interfacing
1.1 Spirit GT, Spirit GTR, Spirit W1
Connect the ESC Throttle cable at the CH0 port. This port is no longer used for a Swashplate servo.
2 Spirit Settings
Power up the model and start the Spirit Settings as usually.
2.1 Telemetry activation
Make sure you have Throttle Channel assigned in the General/Channels window. It is recommended to set Channel 1 for Throttle.
Then set ESC Telemetry in the Spirit Settings software.
Go to the Advanced/Telemetry settings and set the Spektrum Avian option.
3 Displaying telemetry data
