SpiritW1 Binding
1 4 Binding Procedure
In order to Bind Spirit W1 with your Wave radio use supplied Bind plug.
- Insert Bind plug at the SYS port and connect Power supply to the Spirit W1 unit. You can connect BEC or 1-3S Battery at the THR, AUX, T1 ports.
- Spirit W1 unit will start to blink with the Status LED periodically.
- Then power up your Wave radio.
- Radio will automatically bind to the receiver when using new Model profile. You can also Bind anytime manually as described in the section above.
- After successfull binding Spirit unit will stop blinking and will initialize. Then you can remove the Bind plug.
1.1 Manual Binding
You can Bind manually by going to the Model/Receiver menu. Press the Bind button after powering up Spirit W1 with a Bind plug.
