Spirit Wave ESC Telemetry
ESC Telemetry is feature that allows you to display and log data from your Electronic Speed Controller (ESC) directly at the Wave Radio. The ESC Telemetry is mediated through the Spirit unit as these are able to read the data and communicate with both receiver and ESC at the same time.
Spirit Wave has support for all common Telemetry capable ESC protocols.
Spirit W1 units can be interfaced identically to Spirit GT units with all ESCs.
1 List of supported ESCs
2 Interfacing
3 Telemetry data
Available Telemetry variables are dependent on used ESC. Please refer to the section Supported models in particular page of the ESC. Current and Capacity measurement could work only under a load (with main blades on) - depending on ESC model.
  • Battery Voltage [V]
  • Battery Current [A]
  • BEC Current [A] - provided by ESC Telemetry.
4 Telemetry Screen
ESC Telemetry data can be displayed at the Model - ESC - Telemetry page or added at the Main Screen as Widgets.
