OpenTX Integration
Revision as of 22:03, 22 February 2017 by Jocelynr (Talk | contribs) (Created page with "'''Partie la plus courte''' du câble |récepteur")
Guide de configuration
pour l'intégration
Fonctions
Réglage directement depuis l'émetteur
Configuration du module
Pas besoin d'ordinateur
Tout est accessible rapidement
Exigences
OpenTX 2.2 Support Lua
Récepteur avec S.Port
Câble d'intégration pour S.Port
1 Câblage
Partie la plus courte du câble récepteur - S.Port
Longer lead of the cable unit - SYS port
The integration cable is used for bi-­directional data transmission between unit and receiver, respectively transmitter. This include telemetry data and possibility to configure all parameters of the unit, directly from your transmitter.
It is completely separated from basic receiver part that is transmitting the channel data. Thus your existing connection with receiver can be untouched. It can work with PWM, PPM and S­Bus connection types.
Info.png For receiver that has a Molex connector for the S.Port (e.g. X4R, X4R­SB, XSR), please use provided connector and pins so that you can easily connect it to the servo connector.
Info.png S.Port connection alone will not work – it is used only for configuration. Channel data must be transmitted by a conventional protocols such as PWM, PPM or S­Bus.
Example 1: Connection scheme for the Integration part with X4R­SB receiver
Example 2: Optional adapter for X4R, X4R­SB, XSR receivers
2 Installation
Download script for Heli
FrSky Taranis X9D/X9D+/X9E: http://www.spirit-system.com/dl/opentx/Spirit-2.3.0-Taranis.zip
FrSky Horus: http://www.spirit-system.com/dl/opentx/Spirit-2.3.0-Horus.zip
Download script for Aero
FrSky Taranis X9D/X9D+/X9E: http://www.spirit-system.com/dl/opentx/Spirit-Aero-1.0.1-Taranis.zip
FrSky Horus: http://www.spirit-system.com/dl/opentx/Spirit-Aero-1.0.1-Horus.zip
Then unzip the file and copy the „Spirit-­2.3.0“ (or „Spirit-Aero-1.0.1“ for Aero) directory to SD Card of your transmitter.
3 How to open the Menu
  2. Click the PAGE button.
  3. By clicking + and buttons move to the „Spirit-2.3.0“ (or „Spirit-Aero-1.0.1“ for Aero) directory.
  4. Click the ENT button.
  5. Start the basic.lua or special.lua script by clicking the ENT button.
  3. By rotary manipulator move to the „Spirit-­2.3.0“ (or „Spirit-Aero-1.0.1“ for Aero) directory.
4 Integration Preview
FrSky Taranis integration:
FrSky Horus integration:
5 Troubleshooting
  • MLVSS sensor is known to cause interferences on the S.Port line, thus affecting all other sensors including the Integration. We do not recommend to use this sensor at least until the fix will be available.
6 Usage
