Castle Telemetrie
Regulátory Castle Creations podporují tzv. Link Live. Tato funkce umožňuje obousměrný přenos dat pomocí kablíku plynu. Aby mohla telemetrie fungovat, je nezbytné tuto funkci zapnout. Ve výchozím nastavení je vypnuta. Jakmile se povolí, musí také zařízení, které do regulátoru posílá výchylku plynu, tuto funkci podporovat. V tomto případě se musí zapnout na straně jednotky Spirit. V opačném případě by nefungovalo ani řízení plynu.
1 Nastavení regulátoru
Spojte regulátor s Castle Link interface a spusťte konfigurační program Castle Link. Zde je zapotřebí povolit Link Live funkci.
2 Telemetrická propojka
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
For Experts: Alternatively you can modify your current Throttle cable by adding 10kOhm resistor between white (signal) and red (+) wires. In this case the Telemetry cable is not required.
3 Interfacing
Connect the Telemetry cable to the AUX(1) port in the unit, where you normally connect the Throttle cable of the ESC. Connect the Throttle cable to the end of the Telem CC cable.
4.1 Throttle Assignment
Once cable is connected, it is absolutely necessary to assign the Throttle (if not assigned yet).
Go to the General/Channels and assign a channel to the Throttle.
4.2 Telemetry activation
Go to the Advanced/Telemetry settings and set the Castle Creations Phoenix & Talon option.
5 Displaying telemetry data
6 Supported models
Model |
Battery Voltage |
Battery Current |
BEC Voltage |
Consumed Capacity |
ESC Temperature |
Phoenix Edge 50 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge 75 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge 100 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge 130 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge HV 40 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge HV 80 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge HV 120 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge HV 160 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge HVF 160 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite 50 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite 75 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite 100 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite 130 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite HV 40 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite HV 80 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite HV 120 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Edge Lite HV 160 | ✔ | ✔ | ✔ | ✔ | ✔ |
Phoenix Talon 15 | ✔ | x | ✔ | x | ✔ |
Phoenix Talon 25 | ✔ | x | ✔ | x | ✔ |
Phoenix Talon 35 | ✔ | x | ✔ | x | ✔ |
Phoenix Talon 90 | ✔ | x | ✔ | x | ✔ |
Phoenix Talon HV 120 | ✔ | x | ✔ | x | ✔ |
