HobbyWing Telemetrie
Revision as of 13:33, 21 April 2017 by Admin (Talk | contribs) (Created page with "Regulátory HobbyWing Platinum V4 zasílají telemetrii pomocí programovacího portu. Tímto je zprostředkován přenos dat až do jednotky.")
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
Platinum 60A V4 ✔ x x ✔
Platinum 80A V4 ✔ ✔ ✔ ✔
Platinum 120A V4 ✔ ✔ ✔ ✔
Platinum HV 130A V4 ✔ ✔ ✔ ✔
Platinum HV 130A OPTO V4 ✔ ✔ ✔ ✔
Platinum HV 160A V4 ✔ ✔ ✔ ✔
Platinum HV 200A OPTO V4 ✔ ✔ ✔ ✔
