HobbyWing Telemetrie
Revision as of 13:35, 21 April 2017 by Admin (Talk | contribs) (Created page with "Telemetrická propojka")
Regulátory HobbyWing Platinum V4 zasílají telemetrii pomocí programovacího portu. Tímto je zprostředkován přenos dat až do jednotky. Pro fungování ESC telemetrie je nezbytné mít aktuální verzi firmware v regulátoru otáček. Starší verze firmware tuto podporu nemají.
1 Telemetrická propojka
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
Platinum 60A V4 ✔ x x ✔
Platinum 80A V4 ✔ ✔ ✔ ✔
Platinum 120A V4 ✔ ✔ ✔ ✔
Platinum HV 130A V4 ✔ ✔ ✔ ✔
Platinum HV 130A OPTO V4 ✔ ✔ ✔ ✔
Platinum HV 160A V4 ✔ ✔ ✔ ✔
Platinum HV 200A OPTO V4 ✔ ✔ ✔ ✔
