Kontronik Telemetrie
Revision as of 14:04, 21 April 2017 by Admin (Talk | contribs) (Created page with "S verzí firmware Spirit v2.4 je přenos ESC telemetrie možný pouze s připojením EX Bus. Podpora ostatních typů přenosu bude přidána v dalších verzích.")
Regulátory Kontronik KOSMIK a JIVE PRO ESC zasílají telemetrii pomocí vyhrazeného portu. Tímto je zprostředkován přenos dat až do jednotky.
Warning.png S verzí firmware Spirit v2.4 je přenos ESC telemetrie možný pouze s připojením EX Bus. Podpora ostatních typů přenosu bude přidána v dalších verzích.
1 Telemetry Cable
To allow the telemetry data transmission the Telem KONTRONIK cable is required. This cable is available in our Eshop.
2 Spirit Settings
First from all, power up the ESC and start the Spirit Settings as usually.
2.1 Telemetry activation
Set the ESC Telemetry in the Spirit Settings software.
Go to the Advanced/Telemetry settings and set the Kontronik KOSMIK & JIVE PRO option.
Then close the window and save the settings (CTRL+S). Now disconnect the battery.
3 Interfacing
At this step, connect the Telemetry cable according the following photo.
Info.png In this connection SYS port is used. Thus usage of this port for other purposes is limited when the Kontronik telemetry is enabled. Jeti Integration is still available for full configuration of the unit. If you need to use Spirit Settings software, you can deactivate temporarily ESC Telemetry by not turning transmitter on. At this moment normal connection for the USB interface or Wireless connection is established.
4 Displaying telemetry data
When previous steps were finished, you are ready to power up the battery.
After initialization you can display all telemetry data directly in your radio from now.
How to display the data is described in the integration guide:
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
JIVE PRO 80+ HV ✔ ✔ ✔ ✔ ✔
JIVE PRO 120+ HV ✔ ✔ ✔ ✔ ✔
KOSMIK 160 HV ✔ ✔ ✔ ✔ ✔
COOL KOSMIK 160 HV ✔ ✔ ✔ ✔ ✔
KOSMIK 200 HV ✔ ✔ ✔ ✔ ✔
COOL KOSMIK 200+ HV ✔ ✔ ✔ ✔ ✔
COOL KOSMIK 200 HV GOLD ✔ ✔ ✔ ✔ ✔
