Jive Telemetry
Revision as of 08:40, 12 May 2017 by Admin (Talk | contribs)
Kontronik Jive ESC has telemetry feature built-in in the dedicated port (JMP label). This allows telemetry data transmission to the unit.
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
Warning.png It is necessary to modify the cable! Swap orange and red wires in the servo connector of the Telem UNI cable. The Orange wire must be in the middle.
2 Interfacing
Warning.png Do not connect the Telem UNI cable without required modification! This can damage the unit permanently.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik Jive option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
JIVE 80+ HV ✔ ✔ ✔ ✔ ✔
JIVE 120+ HV ✔ ✔ ✔ ✔ ✔
JIVE 80+ LV ✔ ✔ ✔ ✔ ✔
JIVE 120+ LV ✔ ✔ ✔ ✔ ✔
