Wiring
Spirit can be used as a standalone tail gyro or as a flybarless system. Wiring to the unit depends on the type of receiver used.
Spirit is pre-programmed to 1520µs servo neutral impulse and 50Hz frequency – please ensure you have the correct servo parameters selected as specified by your servo manufacturer.
If the neutral impulse of your servo/s is different to the above, such as 760µs, do not connect this servo yet as it could be damaged.
1 STANDALONE GYRO AND FLYBAR
Even if you do have a flybarred model, you can also connect the unit in the same way as a you would a flybarless one. This allows you to use the full potential of the unit including Stabilization and Rescue mode. In order for this to work correctly, it is necessary to tick the Flybar mechanic parameter in the Stabi tab during setup. All other parameters can be configured just the same as with a flybarless head.
2 FLYBARLESS
| μSpirit |
| CH1 – Pitch / Aileron servo |
| CH2 – Elevator servo |
| CH3 – Aileron / Pitch servo |
| CH4 – Rudder servo / Rudder ESC |
| Spirit |
| CH4 – Rudder servo |
| Spirit Pro |
| CH0 – auxiliary (optional) cyclic servo for CCPM 90 swashplate type. |
μSpirit – receiver type: PWM
Spirit Pro
Spirit Pro
Spirit Pro
6 CONNECTION OF PPM RECEIVER
μSpirit – receiver type: PPM
9 CONNECTOR ORIENTATION
9.1 μSpirit
Pin layout of the JST connectors are different from standard Servo connectors. BROWN (Middle) wire is GND pin. ORANGE wire is SIGNAL pin. RED wire is +5V (BEC voltage).
9.2 Spirit and Spirit Pro
