Spektrum Integration
Revision as of 12:36, 1 August 2017 by Admin (Talk | contribs) (Created page with "<languages /> File:Jeti-display.png <translate><!--T:1--> From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spe...")
From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DS/DS 14 or 16 or 24
  • Serial Telemetry receiver - SPM4649T.
  • Spektrum(Jeti) Integration cable available in our stores.
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • For new REX receivers the port label is E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
3 Transmitter preparation
Update your transmitter the latest firmware 1.20 from the Spektrum Airware portal.
5 Integration Menu
When unit is initialized you are able to enter the Spektrum Integration menu. Press the MENU button on the transmitter.
Then select the Telemetry menu by a rotary knob.
6 Usage
7 Preset for transmitter
The profile has enabled:
  • Flight modes
  • Bank Switching
8 Channel Mapping
Channel Layout:
  1. Throttle
  2. Aileron
  3. Elevator
  4. Pitch
  5. Rudder
  6. Gyro sens.
  7. Bank (if used)
  8. Stabi (if used)
9 Telemetry data
