Spektrum Integration
Revision as of 13:02, 1 August 2017 by Admin (Talk | contribs)
From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serial Telemetry receiver - SPM4649T.
  • Jeti Integration cable available in our stores.
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • For new REX receivers the port label is E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
3 Transmitter preparation
Update your transmitter the latest firmware 1.20 from the Spektrum Airware portal.
5 Integration Menu
When unit is initialized you are able to enter the Spektrum Integration menu. Press the MENU button on the transmitter.
Then select the Telemetry menu by a rotary knob.
6 Usage
7 Preset for transmitter
The profile has enabled:
  • Flight modes
  • Bank Switching
8 Channel Mapping
Channel Layout:
  1. Throttle
  2. Aileron
  3. Elevator
  4. Pitch
  5. Rudder
  6. Gyro sens.
  7. Bank (if used)
  8. Stabi (if used)
9 Telemetry data
