Spektrum Integration
Revision as of 15:15, 1 August 2017 by Admin (Talk | contribs)
From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serial Telemetry receiver - SPM4649T.
  • Jeti Integration cable available in our stores.
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
On the receiver side (SPM4649T) the Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding.
  • Then connect the Jeti integration cable to the unit so that red and brown wires are connected to the RUD port.
  • Orange wire should be connected with the AIL pin.
3 Transmitter preparation
Update your transmitter the latest firmware 1.20 from the Spektrum Airware portal.
5 Integration Menu
When unit is initialized you are able to enter the Spektrum Integration menu.
Start the transmitter and use rotary knob - rotate it until you will see Spirit Configuration.
6 Usage
Whenever you want to configure a parameter enter the menu. Then hold the Rudder stick to open the integration. There the Menu Layout is nearly identical with the PC software to have easy navigation.
7 Telemetry data
  • Vibes [%] - Vibration level from all axes (0 - 10% is normal level)
  • RPM [Head RPM] - RPM provided by RPM sensor.
  • Voltage [V] - ESC Telemetry | Main Battery voltage
  • Current [A] - ESC Telemetry | Main Battery current
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
  • Temp [°C] - ESC Telemetry | FET temperature
