Spektrum Integration
Revision as of 15:20, 1 August 2017 by Admin (Talk | contribs)
From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serial Telemetry receiver - SPM4649T.
  • Jeti Integration cable available in our stores.
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • On the receiver side (SPM4649T) the Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding.
  • Then connect the Jeti integration cable to the unit so that red and brown wires are connected to the RUD port.
  • Orange wire should be connected with the AIL pin.
3 Transmitter preparation
Update your transmitter the latest firmware 1.20 from the Spektrum Airware portal.
5 Integration Menu
When unit is initialized you are able to enter the Spektrum Integration menu.
Start the transmitter and use rotary knob - rotate it until you will see Spirit Configuration.
6 Usage
Whenever you want to configure a parameter enter the menu. Then hold the Rudder stick to open the integration. There the Menu Layout is nearly identical with the PC software to have easy navigation.
7 Telemetry data
In order to display Telemetry data go to Menu - Telemetry.
  • Vibes [%] - Vibration level from all axes (0 - 10% is normal level)
  • RPM [Head RPM] - RPM provided by RPM sensor.
  • Voltage [V] - ESC Telemetry | Main Battery voltage
  • Current [A] - ESC Telemetry | Main Battery current
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
  • Temp [°C] - ESC Telemetry | FET temperature
