Spektrum Integration
Revision as of 16:08, 8 August 2017 by Admin (Talk | contribs)
From version 2.4.3 you can use the Spektrum integration! This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serial Telemetry receiver - SPM4649T.
  • Jeti Integration cable available in our stores (or own modification of the wires).
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • uSpirit - 1x SPM4649T + 0-1x Spektrum satellites
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations ESC telemetry primary satellite can be still used.
  • On the receiver side (SPM4649T) the Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding.
  • Then connect the Jeti integration cable to the unit so that red and brown wires are connected to the RUD port.
  • Orange wire should be connected with the AIL pin.
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
5 Integration Menu
At this point the integration menu is closed so you can't accidently configure any parameter. To open the menu, move the Rudder stick to the right and Aileron stick to the left for over 2 seconds. Once the menu is opened, you will see <READY> message. Now you can release the sticks and you are ready to set all the parameters.
5.1 USAGE
Info.png To navitate in the menu you can use Aileron and Elevator sticks.
When using the Bank Switching or Real-Time tuning features the menu will take full control over it. The unit will not react to a Switch position changes. For the Bank Switching there is a parameter Bank in the main menu where you can manually change the banks.
6 Telemetry data
In order to display Telemetry data go to Menu - Telemetry.
  • Vibes [%] - Vibration level from all axes (0 - 10% is normal level)
  • RPM [Head RPM] - RPM provided by RPM sensor.
  • Voltage [V] - ESC Telemetry | Main Battery voltage
  • Current [A] - ESC Telemetry | Main Battery current
  • Capacity [mAh] - ESC Telemetry | Main Battery consumed capacity
  • Temp [°C] - ESC Telemetry | FET temperature
