Spektrum Integration
From version 2.4.3 you can use the Spektrum integration!
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
- Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
- Serial Telemetry receiver - SPM4649T.
- Jeti Integration cable available in our stores (or own modification of the wires).
- Spirit firmware 2.4.3
2 Wiring
The Spektrum cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
- Spirit Pro - 1x SPM4649T + 0-2x Spektrum satellites
- Spirit - 1x SPM4649T + 0-1x Spektrum satellites
- uSpirit - 1x SPM4649T + 0-1x Spektrum satellites
In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations ESC telemetry primary satellite can be still used.
- At the receiver side (SPM4649T) the Jeti integraction cable must be connected to the Servo socket. This socket is used also for Binding.
- Then connect the Jeti integration cable to the unit so that red and brown wires are connected to the RUD port.
- Orange wire should be connected with the AIL pin.
In case that your SPM4649T receiver is not bound yet, you can do so by a BIND PLUG. Connect the bind plug to the socket (same that you are using for the Jeti cable). Then power up the receiver (you can use BEC power supply, free port in the unit such as CH0 or AUX2).
Optional satellites can be binded normally as you are used to do.
3 Transmitter preparation
3.1 Firmware update
3.2 Configuration
Configure:
- 1: ESC
- 2: Text Gen
5 Integration Menu
As soon as you will want to close the Integration menu (when you will want to fly) perform the same procedure with the sticks. Move and hold the sticks (Rudder to the right and Aileron to the left) for over 2 seconds. Menu is closed successfully when <CLOSED> is displayed even that sticks will be in the center. If you will not close the integration menu, it will be temporarily disabled as soon as the Throttle curve will exceed 15%. But to minimize any risk we highly recommend to close it properly.
5.3 Usage
To navitate in the menu you can use Aileron and Elevator sticks.
When using the Bank Switching or Real-Time tuning features the menu will take full control over it. The unit will not react to a Switch position changes. For the Bank Switching there is a parameter Bank in the main menu where you can manually change the banks.
6 Telemetry data
In order to display Telemetry data, move the roller to the right until you will see ESC Status.
- Throttle [%] - Throttle percentage sent to the ESC.
- Output [%] - (Vibration level 0 - 10% is normal level)
- BEC [C] - ESC Telemetry | Main Battery consumed capacity (1234mAh = 123.4C)
