Futaba Telemetry
Revision as of 07:52, 11 August 2017 by Admin (Talk | contribs)
čeština • ‎Deutsch • ‎English • ‎français • ‎magyar • ‎italiano • ‎русский • ‎中文(繁體)‎
From version 2.4.3 you can utilize full support of the Futaba Telemetry!
This mean you can see all telemetry variables sent by Spirit units with S.BUS2 (FASSTest receiver) in real-time.
1 Requirements
  • Futaba transmitter: 14SG, 18MZ or 18SZ
  • FASSTest receiver: R7003SB, R7006SB, R7008SB, R7014SB or R7018SB.
  • FrSky Integration cable available in our stores (with a small modification).
  • Spirit firmware: 2.4.3.
2 Wiring
The FrSky Integration cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
Info.png If S-BUS Adapter is used with Spirit, then it will be replaced by the FrSky Integration cable.
Spirit Pro & uSpirit
Info.png Servo cable that was used for connection between receiver and unit will be replaced by the FrSky Integration cable.
  • At the receiver side - shorter end of the FrSky integraction cable must be connected to the SBUS2 port.
  • At the unit side - longer end must be connected to the RUD and ELE/PIT/AIL ports according the photo.
  • Red wire should be connected with the AIL pin.
Info.png Make sure that the receiver is bound in the FASSTest mode, otherwise telemetry will not work.
3 Transmitter preparation
3.1 Configuration
Power up the transmitter and in the Main menu enter the Sensor page.
Configure:
  • 1: ESC
  • 2: Text Gen
400px
400px
4 Telemetry data
  • Throttle [%] - Throttle percentage sent to the ESC.
  • Output [%] - (Vibration level 0 - 10% is normal level)
  • BEC [C] - ESC Telemetry | Main Battery consumed capacity (1234mAh = 123.4C)
