HobbyWing Telemetry
Revision as of 09:42, 11 August 2017 by Admin (Talk | contribs)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
Warning.png We do not recommend to make this cable since improper connection will cause permanent damage of the unit. The Red wire must be internally disconnected always!
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 60A V4 ✔ x x ✔ ✔
Platinum 80A V4 ✔ ✔ ✔ ✔ ✔
Platinum 120A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A OPTO V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 160A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 200A OPTO V4 ✔ ✔ ✔ ✔ ✔
