Spektrum integrace
Revision as of 13:26, 15 August 2017 by Admin (Talk | contribs) (Created page with "Od verze 2.4.3 jednotky Spirit podporují plnou integraci s vysílači Spektrum.")
This mean you can fully configure Spirit units with Spektrum transmitters in real-time without need of a computer.
1 Requirements
  • Spektrum transmitter: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serial Telemetry receiver: SPM4649T.
  • Jeti Integration cable available in our stores (or own modification of the wires).
  • Spirit firmware: 2.4.3 (with the new Bootloader flashed - see the Troubleshooting section)
2 Wiring
2.1 SPM4649T receiver
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
Info.png In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be binded normally as described in the Manual.
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
5 Integration Menu
5.1 Entering the menu
5.2 Closing the menu
5.3 Navigation
Info.png To navitate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
6 Telemetry data
If the feature is not used, you will still get telemetry variables such as Vibration Level, Throttle percentage and possibly RPM readout as described below.
6.1 Displaying the data
  • Throttle [%] - Throttle percentage sent to the ESC.
  • BEC [C] - ESC Telemetry | Main Battery consumed capacity (1234mAh = 123.4C)
7 Troubleshooting
