HobbyWing Telemetrie
Revision as of 10:24, 20 August 2017 by Buell47 (Talk | contribs) (Created page with "Telemetriekabel")
HobbyWing Platinum V4 ESC verfügt über eine Telemetrie-Funktion, die im Programmieranschluss eingebaut ist. Dies ermöglicht eine telemetrische Datenübertragung an das Gerät. Um die ESC-Telemetrie zu ermöglichen ist es notwendig, das ESC zu aktualisieren, da die älteren Firmware-Versionen es nicht unterstützten.
1 Telemetriekabel
To allow the telemetry data transmission special cable is required. This cable is available in our Eshop.
2 Interfacing
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 60A V4 ✔ x x ✔ ✔
Platinum 80A V4 ✔ ✔ ✔ ✔ ✔
Platinum 120A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 130A OPTO V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 160A V4 ✔ ✔ ✔ ✔ ✔
Platinum HV 200A OPTO V4 ✔ ✔ ✔ ✔ ✔
