Jive Telemetrie
Revision as of 11:20, 20 August 2017 by Buell47 (Talk | contribs) (Created page with "Telemetriekabel")
Kontronik JIVE ESC verfügt über eine Telemetrie-Funktion, die in einem dedizierten Telemetrie-Anschluss (JMP label) eingebaut ist. Dies ermöglicht eine telemetrische Datenübertragung an das Gerät.
1 Telemetriekabel
Warning.png It is necessary to modify the cable! Swap orange and red wires in the servo connector of the Telem UNI cable. The Orange wire must be in the middle.
2 Interfacing
Warning.png Do not connect the Telem UNI cable without required modification! This can damage the unit permanently.
3 Spirit Settings
3.1 Telemetry activation
Go to the Advanced/Telemetry settings and set the Kontronik Jive option.
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
BEC Voltage
Consumed Capacity
ESC Temperature
RPM
JIVE 80+ HV
JIVE 80+ LV
JIVE 100+ LV
JIVE 120+ HV
