Intégration JETI
Revision as of 00:06, 7 November 2017 by GoblinShefford (Talk | contribs) (Created page with "Température FET")
From version 1.1.0 you can use the JETI integration! This mean you can fully configure Spirit units with JETI transmitters in real-time without need of a computer.
1 Exigences
Pour faire fonctionner le tout vous aurez besoin de:
  • Transmetteur Jeti Duplex: DS/DS 14 or 16 or 24
  • Receveur Jeti Duplex avec un port "EX" de libre.
  • Le câble d'intégration Jeti est disponible dans la boutique en ligne de Spirit.
  • Fichier de configuration pour le transmetteur.
2 Câblage
The Jeti cable is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this cable.
  • For new REX receivers the port label is E1 or E2 (EXT port will not work).
  • For older EX receiver the port label is always EXT.
  • To use UDI connection (SRXL/SUMD receiver type) - in this case you will loose the Jeti Integration.
  • To buy a REX receiver where you can use a telemetry sensors and the Jeti integration together.
3 Préparation du transmetteur
Maintenant télécharger Fichier de configuration, which has BIN extension. The file name is "Spirit.bin". This file should be copied to the "Devices" directory on the SD-Card of your transmitter. Without it you will see the error message when the Spirit device is opened.
You can copy it by connecting the micro USB cable to the transmitter similarly as to an USB flash drive. When cable is attached to the transmitter you have to confirm the USB connection. Then simply drag and drop it to the Devices directory as you are used to.
It is very important to use the same version of the BIN file as your current firmware in the unit. If the versions are not matching then an incompatibility issues could occur.
5 Menu intégration
When unit is initialized you are able to enter the Jeti Integration menu. Press the MENU button on the transmitter.
5.1 Stil can't see the Spirit?
6 Usage
7 Preset for transmitter
The profile has enabled:
  • Flight modes
  • Bank Switching
8 Channel Mapping
Channel Layout:
  1. Throttle
  2. Aileron
  3. Elevator
  4. Pitch
  5. Rudder
  6. Gyro sens.
  7. Bank (if used)
  8. Stabi (if used)
9 Données de télémétrie
