Echec du Flashing
Revision as of 19:03, 20 November 2017 by GoblinShefford (Talk | contribs) (Created page with "La connexion entre la radio et l'ordinateur n'est pas stable (vérifiez les câbles).")
1 L'appareil ne fonctionne pas après avoir été flasher
Dans le cas où votre radio ne fonctionne pas correctement après l'avoir flasher, vous pouvez utiliser le guide suivant pour la faire fonctionner à nouveau.
Une question importante a vous poser est, pourquoi cela a échoué?
Les possibilités sont:
  1. Vous avez utilisé un ancien logiciel (version 1.2 et plus ancienne) et flashé un mauvais fichier.
  2. La connexion entre la radio et l'ordinateur n'est pas stable (vérifiez les câbles).
  3. Software issue (installed driver in your computer is not correct) or downloaded firmware had a ".man" extension instead of ".4df" [Most common].
If you are on Windows, please re-install the software with the option for Driver installation. Then it will install correct driver. Then reboot the PC.
If you are on Mac, use this driver: http://spirit-system.com/dl/driver/SiLabsUSBDriverDisk.dmg
Other drivers will very probably not work correctly - especially for the flashing process!
Prerequisities for the recovery process:
  1. Correct driver in your operating system.
  2. Status LED of the unit must flash for a short time during power up.
  3. Disconnect ELE/PIT/AIL cable from the unit (when PWM connection is used).
2 How to revive the unit
  1. Connect the USB interface to your PC and the unit (SYS port).
  2. Start the software. Select NO when prompted for Demo mode.
  3. Go to the Update tab and select firmware you want to flash (4df file extension).
  4. Press the Flash button (and then OK) - you should see "Recovery mode" label in the software.
  5. Power up the unit (from your BEC or a battery). Immediately after power up, flashing should start.
  6. In 20 seconds, unit should be operating again without any issue. Your settings are untouched.
