Spektrum Integration
Revision as of 13:09, 21 February 2018 by Buell47 (Talk | contribs) (Created page with "Empfänger")
Ab der Version 2.4.3 können Sie die Spektrum-Integration nutzen!
Das bedeutet, dass Sie die Spirit-Einheiten mit Spektrum-Sendern in Echtzeit und ohne Computer vollständig konfigurieren können.
1 Voraussetzungen
  • Spektrum Sender: DX6e, DX6 Gen 2, DX6 Gen 3, DX7 Gen 2, DX8 Gen 2, DX9, DX10T, DX18 Gen 1, DX18 Gen 2, DX18T, DX18QQ or DX20
  • Serieller Telemetrie-Empfänger: SPM4649T.
  • Jeti Integration Kabel erhältlich in unseren Geschäften (oder eigene Modifikation der Kabel).
  • Spirit firmware: 2.4.3 (mit dem neuen Bootloader geflasht - siehe Abschnitt Troubleshooting.)
2 Verkabelung
2.1 SPM4649T Empfänger
The receiver is able to transfer everything including channel data and telemetry. This mean that you will not need to connect anything else except this.
Info.png In case that your SPM4649T receiver is not bound yet, you can do so by a Bind plug. Connect the Bind plug to the servo socket. Then power up the receiver (you can use BEC power supply and/or free port in the unit such as CH0 or AUX2). Optional satellites can be binded normally as described in the Manual.
Info.png In case that the ESC telemetry is used, the primary satellite can't be connected. For the Castle Creations and Kontronik Kosmik/Jive Pro ESC telemetry primary satellite can be still used.
3 Transmitter preparation
3.1 Firmware update
  • DX6e does not need update (version 1.00 will work).
3.2 Configuration
Configure:
  • 1: ESC
  • 2: Text Gen
5 Integration Menu
5.1 Entering the menu
5.2 Closing the menu
5.3 Navigation
Info.png To navigate in the menu you can use Aileron and Elevator sticks.
  • Aileron Left - Back in the menu; Stop edit of a parameter' value.
  • Aileron Right - Enter a Submenu; Edit selected parameter.
  • Elevator Up - Go up in the menu or submenu; Increase value of selected parameter.
  • Elevator Down - Go down in the menu or submenu; Decrease value of selected parameter.
6 Telemetry data
6.1 Displaying the data
  • Throttle [%] - Throttle percentage sent to the ESC.
  • BEC [C] - ESC Telemetry | Main Battery consumed capacity (1234mAh = 123.4C)
7 Troubleshooting
