HobbyWing Telemetry
Revision as of 10:30, 25 February 2018 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
HobbyWing Platinum V4 ESC has telemetry feature built-in in the Programming port. This allows telemetry data transmission to the unit. To allow the ESC telemetry, it is necessary to have updated ESC as the older firmware versions were not supporting it.
1 Telemetry Cable
2 Interfacing
Connect the Telemetry cable to the primary Spektrum satellite port in the unit. Smaller Spirit units will utilize the one native Spektrum satellite port (μSpirit - SAT port).
3 Spirit Settings
3.1 Telemetry activation
4 Displaying telemetry data
5 Supported models
Battery Voltage
Battery Current
Consumed Capacity
ESC Temperature
RPM
Platinum 60A V4 x x
Platinum 80A V4
Platinum 120A V4
Platinum HV 130A V4
Platinum HV 130A OPTO V4
Platinum HV 160A V4
Platinum HV 200A OPTO V4
